HEATMAX 6 FT PROOFER-CABINET 6 FT. PROOFER AND FOOD WARMER CABINET
Features- Can be used as a Proofer or Food Warmer
- Fits 16 standard 18 x 26 sheet pans
- Aluminum construction.
- Maintains 140 to 160 degrees
- Single Heating element
- Insulated front door
- 4 in. Casters
- Heavy duty door latch
- Analog temperature thermometer
- Humidity pan at the bottom to add water to use as a proofer.
Specifications- Front Door Clearance - 19 in.
- Number of Shelves - 16
- Heating Elements - 2
- Amps - 9
- Dimension - 23 x 30 x 72 in.
- Item weight - 120 Lbs.
Price: 1178.45
